Hey deHakkelaar,
Thanks for the response. I didn't know that pihole was using dhcpcd5 as a dhcp client. If that's the case, what I would rather do would be to remove dhcpcd5 instead apt-get remove --purge dhcpcd5, and let the old school network manager handle dhcp client duties.
A little bit of background, the bridge is for VMs running on QEMU/KVM. When one comes up, it's automatically added to the bridge.
Here's an updated interfaces file:
# The loopback network interface
auto lo
iface lo inet loopback
# The eth0 interface
iface eth0 inet manual
# The primary network interface
auto virbr0
iface virbr0 inet dhcp
bridge_ports eth0
bridge_stp off
bridge_maxwait 0
bridge_fd 0
Here's the output of ifconfig for relevant interfaces:
eth0 Link encap:Ethernet HWaddr d4:3d:7e:9e:9d:e2
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:7146 errors:0 dropped:0 overruns:0 frame:0
TX packets:5408 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1004296 (1.0 MB) TX bytes:696453 (696.4 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1097 errors:0 dropped:0 overruns:0 frame:0
TX packets:1097 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:83246 (83.2 KB) TX bytes:83246 (83.2 KB)
virbr0 Link encap:Ethernet HWaddr d4:3d:7e:9e:9d:e2
inet addr:192.168.0.201 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: 2606:6000:cd41:5d00:a14a:b1ff:e129:cb63/64 Scope:Global
inet6 addr: 2606:6000:cd41:5d00:d63d:7eff:fe9e:9de2/64 Scope:Global
inet6 addr: fe80::d63d:7eff:fe9e:9de2/64 Scope:Link
RX packets:6937 errors:0 dropped:0 overruns:0 frame:0
RX bytes:852990 (852.9 KB) TX bytes:696453 (696.4 KB)
And Pihole is still failing to resolve.
https://tricorder.pi-hole.net/l6afmoa0a5
However.
If I install Pihole on eth0 instead of virbr0, DNS resolution works the first time after install. After a reboot, it no longer works. Here's the ifconfig output after reboot.
RX packets:334 errors:0 dropped:0 overruns:0 frame:0
TX packets:272 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:46977 (46.9 KB) TX bytes:36266 (36.2 KB)
RX packets:587 errors:0 dropped:0 overruns:0 frame:0
TX packets:587 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:45963 (45.9 KB) TX bytes:45963 (45.9 KB)
inet6 addr: 2606:6000:cd41:5d00:e896:ffb:91a6:f0cf/64 Scope:Global
RX bytes:42217 (42.2 KB) TX bytes:36266 (36.2 KB)
user@server:~$ sudo pihole status
[✗] DNS service is NOT running
Now I run dhclient eth0 and get an IP address for eth0 (201 as reserved by my router), and run pihole restartdns. It works!
Okay, so it looks like the issue is maybe that eth0 should be configured by dhcp at boot? After all, that's what I'm doing manually with dhcp client eth0, right?
So I change my /etc/network/interfaces file to:
auto lo
auto eth0
iface eth0 inet dhcp
auto virbr0
bridge_ports eth0
bridge_stp off
bridge_maxwait 0
bridge_fd 0
and reboot.
However, now I can't ping or ssh into my server. Is it because both eth0 and virbr0 are getting the same dhcp config as eachother, and they're on a bridge, so there's contention?
If I run a dhclient eth0 followed by pihole restartdns once again, everything works. Am I supposed to install pihole on the eth0 interface instead of the bridge? What networking options am I screwing up to get this to work at boot?
