Can't get admin password and debug code
Hello! At the end of installation I expect to see window like this with password.!
Screen Shot 2020-04-20 at 21.18.25|690x429
But I see this without admin password:
And if I try go by admin panel URL then I see this:
I use Orange PI One and Armbian Bionic OS.
I can't give you debug code. You can see reason on screen:(
The Pi-hole installation did not appear to complete. Run the verbose version of the installer and the last step will tell you where the installer stopped:
curl -sSL https://install.pi-hole.net | sudo bash -x
By this command I got installation completed successfully from first attempt and now I know password!
Thank you!
