Can't enable https with self-signed certificate
I'm running my Pi-hole (Pi-hole v5.17.2, FTL v5.23 and Web Interface v5.20.2) in Ubuntu Server 22.04, this server is a Proxmox VM. I want to enable HTTPS access to the Pi-hole Admin-Web-Interface via a self-signed SSL certificate.
That's what I've done:
After trying a lot of things, it has been impossible to enable https for my Pi-hole.
https://tricorder.pi-hole.net/glAQFC8n/
Thank you very much and best regards!! :smiley:
The file /etc/lighttpd/external.conf is not used if you did a fresh install
(this file was used in older versions and will be only read if you are updating from versions prior to v5.15).
If you did a fresh install, every custom config file should be in /etc/lighttpd/conf-enabled/.
You can try to adapt the file you created and move it to: /etc/lighttpd/conf-enabled/20-pihole-external.conf (you can name the file as you like, but the files are loaded in alphabetical order).
Yeeeah, after fighting for one week, now it's working!!! 1.000.000 thanks for your help!!!!
  • I've created the folder /etc/lighttpd/ssl and ran the commands for the certificates:
openssl req -newkey rsa:2048 -nodes -keyout pihole.key -x509 -days 365 -out pihole.crt
cat pihole01.key pihole01.crt > combined.pem
  • Next, I've ensured the lighttpd user www-data can read the required certificates:
sudo chown www-data -R /etc/letsencrypt/live
  • I've created the file /etc/lighttpd/conf-enabled/20-pihole-external.conf with this content inside:
   #Loading openssl
server.modules += ( "mod_openssl" )
setenv.add-environment = ("fqdn" => "true")
$SERVER["socket"] == ":443" {
	ssl.engine  = "enable"
	ssl.pemfile = "/etc/lighttpd/ssl/combined.pem"
	ssl.openssl.ssl-conf-cmd = ("MinProtocol" => "TLSv1.3", "Options" => "-ServerPreference")
# Redirect HTTP to HTTPS
$HTTP["scheme"] == "http" {
    $HTTP["host"] =~ ".*" {
        url.redirect = (".*" => "https://%0$0")
  • Finally, I've executed:
    systemctl restart lighttpd.service
And voilà, https enabled:
Again, @rdwebdesign thank you very much!! :smiley: :smiley:
Best regards.
