Cant define whitelist
When I try to define a domain at white list pihole say "attempt to write a readonly database".
I try to unistall an install but say the same.
I am using nginx instead of lighttpd because I use this for other uses
https://tricorder.pi-hole.net/a8s1u4qiuy
You're likely missing the right permissions, packages and/or group assignments
https://docs.pi-hole.net/guides/nginx-configuration/
I Try this but is the same. Say that is read only.
Have you searched the forum for the issue and nginx?
Does this help:
Thanks.
At the end with the indicated post you can fix it. Not as indicated in these but including the user www-data in the group pihole and the user pihole in the group www-data.
The one suggested in the post did not work for me but doing it double did.
