After hitting the online update button, I get a connection failed error for all added lists. I also can't generate a debug token: curl: (7) Failed to connect to tricorder.pi-hole.net port 443: No route to host
If you have a desktop and browser installed on it, open those up and try browsing the web as normal. Or open a terminal and see if you can ping Google and grab the example.com web page. It will help see if you can can connect out and have internet access and the problem is just Pi-hole, or if there is a wider problem.
ping -c 5 www.google.com
curl http://example.com | head
I get the following reply form the terminal. So it seems to be an internet problem?
PING www.google.com (142.251.39.100) 56(84) bytes of data.
From 192.168.2.100 (192.168.2.100) icmp_seq=1 Destination Host Unreachable
From 192.168.2.100 (192.168.2.100) icmp_seq=2 Destination Host Unreachable
From 192.168.2.100 (192.168.2.100) icmp_seq=3 Destination Host Unreachable
From 192.168.2.100 (192.168.2.100) icmp_seq=4 Destination Host Unreachable
From 192.168.2.100 (192.168.2.100) icmp_seq=5 Destination Host Unreachable
--- www.google.com ping statistics ---
5 packets transmitted, 0 received, +5 errors, 100% packet loss, time 4077ms
pipe 3
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
curl: (7) Failed to connect to example.com port 80: No route to host
Aye looks like the whole setup has no network. The ifconfig command will show if you have network interfaces (ethernet port or wifi) that have IP addresses on your network (eg 192.168.something or maybe 10.something).
What about other devices on your network, can they access the Internet okay, eg laptops, phones, etc?
If they're okay and it's just the DietPi that's offline, you probably need to enable networking in its settings somewhere. I don't know enough about DietPi to know how to do it, there's probably a menu you use to set up its networking.
That's also what my conclusion was but the strange thing is that the pihole's dashboard is working and showing that some domains have been blocked.
All other devices can access the network like normal
