Can't access pi-hole's admin interface
I try to reach the admin page by going to
http://pi.hole/admin
http://<IP_ADDPRESS_OF_PI_HOLE>/admin/
I just installed pi-hole in my raspberry pi and tried to log in using pc and got an error in the browser "Connection timeout"
I can log in using my phone
https://tricorder.pi-hole.net/40cxkOPG/
After you made the DNS change in your DHCP server (your router), did you renew the DHCP lease on all clients so they will pick up the new DNS assignment?
From this particular PC, from the command prompt on the PC (and not via ssh to Pi-hole), what are the outputs of the following commands:
nslookup pi.hole
nslookup pi.hole 192.168.188.48
nslookup pi.hole
Server:  fritz.box
Address:  fd00::de15:c8ff:febb:82ca
*** No internal type for both IPv4 and IPv6 Addresses (A+AAAA) records available for pi.hole
Server:  pi.hole
Address:  192.168.188.48
Addresses:  2001:14ba:a0e9:2e00:6388:fcfe:aba2:9d6b
          192.168.188.48
This client is not using Pi-hole for DNS. It is using an IPV6 DNS server provided by the FritzBox.
When you specifically direct the DNS query to Pi-hole, Pi-hole correctly responds.
We have a guide how to setup Pi-hole with FritzBoxes Fritz!Box (EN) - Pi-hole documentation
