So I am switching my pihole server from a raspberry pi to an old laptop along with a webserver. For this reason I chose to use the docker implementation and because I need port 80 open for the http server I changed the exposed port/forwarded the port to port 6578, so that my docker-compose.yml
file looks like this :
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "6578:80/tcp"
environment:
TZ: 'America/New_York'
WEBPASSWORD: '6nYmKYSgTgtY'
PIHOLE_DNS_: 1.1.1.1
WEBTHEME: "default-dark"
VIRTUAL_HOST: '192.168.1.162:6578'
volumes:
- './etc-pihole/:/etc/pihole/'
- './etc-dnsmasq.d/:/etc/dnsmasq.d/'
restart: unless-stopped
I have no issue getting a response at pi.hole
and 192.168.1.162:6578
however if I click the admin link or try pi.hole/admin
and 192.168.1.162:6578/admin
the admin page doesn't load.
Running on an Arch linux Kernel: Linux 5.14.2-arch1-2
Fresh container, I haven't tried switching my router DNS server setting to the new container because I would like to/need to configure internal DNS entries first.
This is the log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] 01-resolver-resolv: applying... ,
[fix-attrs.d] 01-resolver-resolv: exited 0.,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] 20-start.sh: executing... ,
::: Starting docker specific checks & setup for docker pihole/pihole,
[i] Installing configs from /etc/.pihole...,
[i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone!,
[i] Installing /etc/dnsmasq.d/01-pihole.conf...
[✓] Installed /etc/dnsmasq.d/01-pihole.conf,
[i] Installing /etc/.pihole/advanced/06-rfc6761.conf...
[✓] Installed /etc/dnsmasq.d/06-rfc6761.conf,
Setting DNS servers based on PIHOLE_DNS_ variable,
Setting Web Theme based on WEBTHEME variable, using value default-dark,
::: Pre existing WEBPASSWORD found,
DNSMasq binding to default interface: eth0,
Added ENV to php:,
"PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",,
"ServerIP" => "0.0.0.0",,
"CORS_HOSTS" => "",,
"VIRTUAL_HOST" => "192.168.1.162:6578",,
Using IPv4 and IPv6,
::: setup_blocklists now setting default blocklists up: ,
::: TIP: Use a docker volume for /etc/pihole/adlists.list if you want to customize for first boot,
::: Blocklists (/etc/pihole/adlists.list) now set to:,
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts,
::: Testing pihole-FTL DNS: FTL started!,
::: Testing lighttpd config: Syntax OK,
::: All config checks passed, cleared for startup ...,
::: Enabling Query Logging,
[i] Enabling logging...,
[✓] Logging has been enabled!,
::: Docker start setup complete,
Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf,
Pi-hole version is v5.4 (Latest: v5.4),
AdminLTE version is v5.6 (Latest: v5.6),
FTL version is v5.9 (Latest: v5.9),
Container tag is: pihole/pihole:2021.09-amd64-buster,
[cont-init.d] 20-start.sh: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
Starting lighttpd,
Starting pihole-FTL (no-daemon) as root,
Starting crond,
[services.d] done.,
Stopping pihole-FTL,
