Can't acces the Pi-Hole web interface
[I just installed Pi-Hole on my raspberry pi 4]
[Im trying to acces the Pi-Hole interface but i can't it says DNS_PROBE_FINISHED_NXDOMAIN ]
[ https://tricorder.pi-hole.net/is99xpi8on]
Your're running nginx on port 80
[80] is in use by nginx (https://docs.pi-hole.net/main/prerequisites/#ports)
Your router advertises two non-Pi-hole DNS servers via DHCP
   Timeout: 10 seconds
   * Received 548 bytes from eth0:192.168.0.1
     Offered IP address: 192.168.0.33
     Server IP address: 192.168.0.1
     Relay-agent IP address: N/A
     BOOTP server: (empty)
     BOOTP file: (empty)
     DHCP options:
      Message type: DHCPOFFER (2)
      server-identifier: 192.168.0.1
      lease-time: 3600 ( 1h )
      netmask: 255.255.255.0
      router: 192.168.0.1
      dns-server: 24.55.102.2
      dns-server: 24.138.252.19
Please run from one client
nslookup pi.hole
Do I need to change something there?
I would select "DNS override" and enter Pi-holes's IP as primary DNS server IP. Remove all other IPs. (If not possible enter 0.0.0.0 for secondary and tertiary). Click apply and dis/reconnect your clients from the network to pickup the new settings via DHCP.
Just did that but my network really slow and when I tried to accees the interface it said that it couldnt find the pi-hole dns
https://tricorder.pi-hole.net/msc48eb73w
Now im trying to set a static ip for the dns but idk if I should change my default domain name or just leave it how it is
It now adverties Pi-hole's IP as DNS server via DHCP - that's good.
   Timeout: 10 seconds
     BOOTP file: (empty)
     DHCP options:
      router: 192.168.0.1
      dns-server: 192.160.0.33
Did you
And
I would not fiddle here... it looks like it is the setting for your router's WAN interface.
You need to set a static IP for the device hosting Pi-hole on the device itself
Srry for taking this long, right now I see the dns is getting detected but now for some reason im not getting internet connection and when I try to access the web interface is saying pi.hole ’s server IP address could not be found last token- https://tricorder.pi-hole.net/jvr44uwgyh
Compared to your last debug log, Pi-hole has received and processed queries from different clients.
   [2021-03-14 12:23:59.100 5193M] Imported 14 queries from the long-term database
   [2021-03-14 12:23:59.100 5193M]  -> Total DNS queries: 14
   [2021-03-14 12:23:59.100 5193M]  -> Cached DNS queries: 6
   [2021-03-14 12:23:59.100 5193M]  -> Forwarded DNS queries: 8
   [2021-03-14 12:23:59.100 5193M]  -> Blocked DNS queries: 0
   [2021-03-14 12:23:59.100 5193M]  -> Unknown DNS queries: 0
   [2021-03-14 12:23:59.100 5193M]  -> Unique domains: 6
   [2021-03-14 12:23:59.100 5193M]  -> Unique clients: 1
   [2021-03-14 12:23:59.100 5193M]  -> Known forward destinations: 1
   [2021-03-14 12:23:59.100 5193M] Successfully accessed setupVars.conf
   [2021-03-14 12:23:59.106 5195M] PID of FTL process: 5195
   [2021-03-15 09:54:42.800 1249M] Imported 5191 queries from the long-term database
   [2021-03-15 09:54:42.800 1249M]  -> Total DNS queries: 5191
   [2021-03-15 09:54:42.800 1249M]  -> Cached DNS queries: 2409
   [2021-03-15 09:54:42.800 1249M]  -> Forwarded DNS queries: 1901
   [2021-03-15 09:54:42.800 1249M]  -> Blocked DNS queries: 10
   [2021-03-15 09:54:42.800 1249M]  -> Unknown DNS queries: 42
   [2021-03-15 09:54:42.800 1249M]  -> Unique domains: 104
   [2021-03-15 09:54:42.800 1249M]  -> Unique clients: 6
   [2021-03-15 09:54:42.800 1249M]  -> Known forward destinations: 2
Even though if I have to repeat it again:
Please run from the affected client
nslookup pi.hole
