--VMfusion v13.6.0, Ubuntu server v24.04, Pi-holev5.18.3--
i followed the Pi-hole installation guide and continued to the till the end of the installation process skipping the encountered errors, i tried to looking at other posts and tried running exact same troubleshoots but i do not think its my network as i am able to ping whatever sever you wish and able to run 2 out of the 3 dig cmds the following are the errors i encountered:
Input: $ dig fail01.dnssec.works @127.0.0.1 -p 5335
return
;; communications error to 127.0.0.1#5335: timed out ;; communications error to 127.0.0.1#5335: timed out
so i ran
unbound-checkconf
output
unbound-checkconf: no errors in /etc/unbound/unbound.conf
and also ran:
unbound -d
return:
Sep 30 11:14:31 unbound[17713:0]
warning: so-rcvbuf 1048576 was not granted. Got 425984.
To fix: start with root permissions(linux) or sysctl bigger net.core.rmem_max(linux) or kern.ipc.maxsockbuf(bsd) values.
Sep 30 11:14:31 unbound[17713:0] error: can't bind socket: Address already in use for 127.0.0.1 port 5335
Sep 30 11:14:31 unbound[17713:0] fatal error: could not open ports
the so-rcvbuf warning is not a issue as i have already edited /etc/sysctl.conf and placed net.core.rmem_max=1048576
inside the file and had the error gone but its back and i think its because of the maybe the binding of the socket error causing it or the fatal error can't open ports.
inputs: nslookup pi-hole.net
returns:
Server: 9.9.9.9
Address: 9.9.9.9#53
Non-authoritative answer:
Address: 3.18.136.52
input: nslookup pi-hole.net 8.8.8.8
returns:
Server: 8.8.8.8
Address: 8.8.8.8#53
inputs:
nslookup ns-407.awsdns-50.com 8.8.8.8
returns:
Server: 8.8.8.8
Address: 8.8.8.8#53
Address: 205.251.193.151
Address: 2600:9000:5301:9700::1
inputs:
nslookup ns-407.awsdns-50.com 127.0.0.1
returns:
Server: 127.0.0.1
Address: 127.0.0.1#53
inputs:
dnslookup -port=5335 ns-407.awsdns-50.com 127.0.0.1
returns:
Address: 127.0.0.1#5335
#---the last one i noticed is only one using port 5335---#
#------------------new-----debug---------#
inputs:
sudo grep -v '#|^$' -R /etc/unbound/unbound.conf*
returns:
/etc/unbound/unbound.conf:server:
/etc/unbound/unbound.conf: include-toplevel: "/etc/unbound/unbound.conf.d/*.conf"
/etc/unbound/unbound.conf.d/remote-control.conf:remote-control:
/etc/unbound/unbound.conf.d/remote-control.conf: control-enable: yes
/etc/unbound/unbound.conf.d/remote-control.conf: control-interface: /run/unbound.ctl
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf: auto-trust-anchor-file: "/var/lib/unbound/root.key"
/etc/unbound/unbound.conf.d/pi-hole.conf: logfile: "/var/log/unbound/unbound.log"
/etc/unbound/unbound.conf.d/pi-hole.conf: log-time-ascii: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: verbosity: 0
/etc/unbound/unbound.conf.d/pi-hole.conf: interface: 127.0.0.1
/etc/unbound/unbound.conf.d/pi-hole.conf: port: 5335
/etc/unbound/unbound.conf.d/pi-hole.conf: access-control: 127.0.0.0/8 allow
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip4: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-udp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-tcp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: prefer-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-glue: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-dnssec-stripped: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: use-caps-for-id: no
/etc/unbound/unbound.conf.d/pi-hole.conf: edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/pi-hole.conf: prefetch: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: num-threads: 2
/etc/unbound/unbound.conf.d/pi-hole.conf: so-rcvbuf: 1m
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 192.168.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 169.254.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 172.16.0.0/12
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 10.0.0.0/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fd00::/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fe80::/10
inputs:
sudo lsof -i :5335
return:
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
unbound 14133 unbound 3u IPv4 61996 0t0 UDP localhost:5335
unbound 14133 unbound 4u IPv4 61997 0t0 TCP localhost:5335 (LISTEN)
unbound 14133 unbound 5u IPv4 61998 0t0 UDP localhost:5335
unbound 14133 unbound 6u IPv4 61999 0t0 TCP localhost:5335 (LISTEN)
#---in my debug log i noticed /etc/lighttpd/conf.d does not exist, but was able to diagnose its contents---#
#--ipv6 failed to resolve should be fine, as have not config for ipv6---#
my input:
sudo systemctl status unbound.service
return:
Starting unbound.service - Unbound DNS server...
(unbound)[14133]: unbound.service: Referenced but unbound.service: Referenced but unset environment variable evaluates to an empty string: daemon_opts
warning: so-rcvbuf 1048576 was not granted. Got 425984. To fix: start with root perm 425984. To fix: start with root permissions(linux) or sysctl bigger net.core
input:
sudo lsof -i :53
return
pihole-FT 10357 pihole 4u IPv4 30704 0t0 UDP *:domain
pihole-FT 10357 pihole 5u IPv4 30705 0t0 TCP *:domain (LISTEN)
pihole-FT 10357 pihole 6u IPv6 30706 0t0 UDP *:domain
pihole-FT 10357 pihole 7u IPv6 30707 0t0 TCP *:domain (LISTEN)
#---should i disable system resolve, i know this should be disable on debian but im on ubuntu, and set my nameservers address to also 127.0.0.1---#
#---my expected outcome was to remove the errors, transition from port 53 to 5335, i also ran sudo ufw allow 5335 after running sudo systemctl status unbound.service.
i also tried systemctl edit unbound and changing the $daemon_opts to 5335
but that caused a exit failure error so i reverted
Pi-hole system does match actual IP time ----#
#----much assistance is appreciated---#
--VMfusion v13.6.0, Ubuntu server v24.04, Pi-holev5.18.3---
