What im using:
Ubuntu 22.04 LTS
Docker
I used the quickstart from https://github.com/pi-hole/docker-pi-hole. The container says its healthy. I did not change anything in the yml file. I got the ip for pihole using docker inspect -f '{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}' pihole. I have not changed the DNS in the router because using http://<IP_ADDPRESS_OF_YOUR_PI_HOLE>/admin/ is supposed to work without changing the DNS: How do I access Pi-hole's Dashboard admin interface?
Be able to enter the pihole web interface
Timeout when using pihole ip, and This site can’t be reached when using http://pi.hole
https://tricorder.pi-hole.net/5jqrNsxl/
Please post the docker run command or compose file used to start the container.
I used docker compose up -d with the yml file in the github:
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
- "80:80/tcp"
environment:
TZ: 'America/Chicago'
# WEBPASSWORD: 'set a secure password here or it will be random'
volumes:
- './etc-pihole:/etc/pihole'
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
cap_add:
- NET_ADMIN # Required if you are using Pi-hole as your DHCP server, else not needed
restart: unless-stopped
^ I used this exact yml file
Try to start a new container adding the recommended environment variable FTLCONF_LOCAL_IPV4 to your compose file:
environment:
FTLCONF_LOCAL_IPV4: '<IP_ADDPRESS_OF_YOUR_PI_HOLE>'
This worked, thank you. For anyone else looking at this I also added a password enviroment variable, probably doesn't affect this issue, but adding just in case.
