Cannot access web interface - lighttpd not running
PiHole inital install
All other systems working fine
https://tricorder.pi-hole.net/q0bk9qcx0x
Is there already a Apache webserver running on that system?
Not that I'm aware of. I set up a new raspbian lite image. Do you have a command I could use to check?
Running sudo service httpd status gives "unit httpd.service could not be found"
i have similar problem with new installation. My lighttpd running but without inetrface..
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-09-10 12:18:12 EEST; 9min ago
Process: 256 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 402 (lighttpd)
Memory: 6.3M
CGroup: /system.slice/lighttpd.service
└─402 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
Sep 10 12:18:07 raspberrypi systemd[1]: Starting Lighttpd Daemon...
Sep 10 12:18:12 raspberrypi systemd[1]: Started Lighttpd Daemon.
https://imgur.com/ggC0ZnJ.png
Your debug token is: https://tricorder.pi-hole.net/ul5eqdgaou
Don't know what operating system you both use, but can you please read or check
for me no luck...
No help. Made no difference to my error logs either. The lighttpd daemon is still offline.
Hi
I had the same boring problem.
Pi-hole was running good (for some months) and after a update no more web-interface was aviable.
I followed the insctructions on Lighttpd does not start - #11 by djcraysey but this didn't solved the problem.
But the Idea was good: Installing a program that contains lighttpd.
So I found a workaround:
sudo apt-get install gamin (this re-installs lighttpd)
sudo apt-get purge gamin (this uninstalls lighttpd)
curl -sSL https://install.pi-hole.net | bash (this re-installs lighttpd for the pi-hole).
For me it worked, I hope it will help you too.
Brilliant, this worked! Thank you!
Damn this worked! Thank you! !!
sudo service lighttpd status is the correct command
After a update the same problems are here.
For me it looks like when "apt update" updates lighttpd, the pi-hole settigs are overwritten and the web-interface is no more aviable. Perhaps on another port?
I have updated and simplified my workaround above:
sudo apt purge lighttpd
sudo pihole -r
Best regards
Christopher
