cannot access tricorder, http://pi.hole/ doesn't load but IP/admin does work. + few small things
I'm running eero w/DNS pointed solely at local IP for docker host (IPv4 & IPv6). All extra features on eero have been disabled.
I used this docker container to setup pihole+unbound , this is the output of top command on my docker container host running ubuntu LTS. The only other thing i have running is an enshrouded server but that likely won't stay forever.
I'm open to moving off of docker / shared host and onto a seperate pi if its advisable, but would prefer not if i don't have to.
root@precision:~/docker/pihole-unbound# top
top - 12:33:42 up 6 days, 21:57,  2 users,  load average: 0.83, 0.85, 0.86
Tasks: 334 total,   1 running, 333 sleeping,   0 stopped,   0 zombie
%Cpu(s):  6.9 us,  0.6 sy,  0.0 ni, 92.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :  31756.0 total,  24926.2 free,   2981.9 used,   4360.4 buff/cache
MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  28774.1 avail Mem
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
 291836 4711      20   0 5851956   1.3g  46040 S  90.0   4.2     4d+7h enshrouded_serv
 291788 4711      20   0   16300  15020   2408 S   0.7   0.0  53:58.08 wineserver
    103 root     -51   0       0      0      0 S   0.3   0.0   2:11.70 irq/9-acpi
    853 avahi     20   0    9848   4988   4092 S   0.3   0.0  21:49.78 avahi-daemon
    999 root      20   0  334576  17600   7360 S   0.3   0.1   5:34.58 upowerd
   2062 root      20   0 3818348  83832  54136 S   0.3   0.3  10:40.07 dockerd
 151705 root      20   0   38600  28728  11632 S   0.3   0.1   2:22.89 supervisord
This is my docker compose file
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    network_mode: host
    ports:
      # DNS Ports
      - "53:53/tcp"
      - "53:53/udp"
      # Default HTTP Port
      - "80:80/tcp"
      # Default HTTPs Port. FTL will generate a self-signed certificate
      - "443:443/tcp"
      # Uncomment the below if using Pi-hole as your DHCP Server
      #- "67:67/udp"
    #dns:
      #- 127.0.0.1
    environment:
      # Set the appropriate timezone for your location from
      # https://en.wikipedia.org/wiki/List_of_tz_database_time_zones, e.g:
      TZ: ${TZ}
      # Set a password to access the web interface. Not setting one will result in a random password being assigned
      FTLCONF_webserver_api_pwhash: 'redacted'
      # If using Docker's default `bridge` network setting the dns listening mode should be set to 'all'
      FTLCONF_dns_listeningMode: 'all'
      FTLCONF_dns_upstreams: '127.0.0.1#5335' # Unbound
      # Don't use pihole as a NTP Server
      FTLCONF_ntp_ipv4_active: ${NTP_IPV4_ACTIVE:-true}
      FTLCONF_ntp_ipv6_active: ${NTP_IPV6_ACTIVE:-true}
      FTLCONF_ntp_sync_active: ${NTP_IPV6_ACTIVE:-true}
    volumes:
      # For persisting Pi-hole's databases and common configuration file
      - '/srv/docker/pihole-unbound/pihole/etc-pihole:/etc/pihole'
      # Uncomment the below if you have custom dnsmasq config files that you want to persist. Not needed for most starting fresh with Pi-hole v6. If you're upgrading from v5 you and have used this directory before, you should keep it enabled for the first v6 container start to allow for a complete migration. It can be removed afterwards. Needs environment variable FTLCONF_misc_etc_dnsmasq_d: 'true'
      #- '/srv/docker/pihole-unbound/pihole/etc-dnsmasq.d:/etc/dnsmasq.d'
    cap_add:
      # See https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
      # Required if you are using Pi-hole as your DHCP server, else not needed
      #- NET_ADMIN
      # Required if you are using Pi-hole as your NTP client to be able to set the host's system time
      #- SYS_TIME
      # Optional, if Pi-hole should get some more processing time
      - SYS_NICE
    restart: unless-stopped
  unbound:
    container_name: unbound
    image: mvance/unbound:latest # Change to use 'mvance/unbound-rpi:latest' on raspberry pi
    # use pihole network stack
    network_mode: service:pihole
    volumes:
      # main config
      - ./unbound-config/unbound.conf:/opt/unbound/etc/unbound/unbound.conf:ro
      # custom config (unbound.conf.d/your-config.conf). unbound.conf includes these via wilcard include
      - ./unbound-config/unbound.conf.d:/opt/unbound/etc/unbound/unbound.conf.d:ro
      # log file
      - /srv/docker/pihole-unbound/unbound/etc-unbound/unbound.log:/opt/unbound/etc/unbound/unbound.log
    post_start:
      # remove unused config files
      - command: rm -f /opt/unbound/etc/unbound/a-records.conf
      - command: rm -f /opt/unbound/etc/unbound/forward-records.conf
      - command: rm -f /opt/unbound/etc/unbound/srv-records.conf
this is the output of nslookup pi.hole from different machine than docker host
nslookup pi.hole
Server: UnKnown
Address: 192.168.5.34 (docker host IP)
Address: 172.20.0.2
So far things have been fine with few exceptions.
  • Have to use direct IP to access pihole dashboard
  • ipad couldn't access netflix last night unless i changed DNS to use googles DNS
  • xbox gamepass was working previously while using pihole but wouldn't work today until i added live.com to whitelist & did reloaddns on pihole
  • images / sites feel like they are loading slower.
https://tricorder.pi-hole.net/MpjUw45c/
This is normal. Only Pi-hole team members have access to the uploaded logs.
You can find your own log at /var/log/pihole/pihole_debug.log.
What do you see if you access http://pi.hole/admin (you need to include /admin) ? Any error messages?
Thanks for the tip on why i shouldn't be able to see my logs via that link, will check out local logs now to see if I can spot anything.
If i use the pi.hole/admin it jsut says cannot be reached connection timed out
