Cannot access raspberrypi from IPhone using same URL local WLAN or VPN Tailscale
When accessing a raspberrypi 5 web resource from my IPhone I should be able to use the same URL
regardless of
  • whether I am connected locally on my home wifi
  • or coming from outside into my home wifi through Tailscale VPN
I have done the following:
  • Installed Pihole on my raspberrypi (docker and docker compose)
  • Changed my router (FritzBox 7590) config:
    • IPv4 settings: Local DNS server:
    • Set ULA Prefix manually, keep fd00, rest empty (german: ULA-Präfix manuell festlegen)
    • IPv6 settings: Uncheck Publish DNSv6 server through router advertisement (german: DNSv6-Server auch über Router Advertisement bekanntgeben)
    • Local DNSv6 server: fd00:0:0:0:<last 4 octets of IPv6 address of my raspberrypi>
  • Disconnected Iphone from Wifi and reconnected
From IPhone:
I am aware this is not a pi-hole issue but a DNS config issue, but since I am tampering with my FritzBox only because of pihole I am hoping others have similiar experience and have solved the issue.
Replace this text with the debug token provided from running pihole -d
Since I have a docker installation, “the command
which pihole
delivers nothing.
I can log in into the admin web page of pi-hole and see everything but I can’t find “generate debug token” under Tools or anywhere else.
So probably I need help here first :frowning:
Thanks for any help.
Debug token generated through:
docker exec -it pihole
https://tricorder.pi-hole.net/dd1REK0c/
This Behavior is expected.
raspberryname.local is resolved via mDNS (via Bonjour and avahi-daemon), using multicast. This only works on the same local link, or sometimes over VLANs. This will realistically never work over any VPN.
raspberryname is probably resolved via Tailscale`s MagicDNS. This MagicDNS service is obviously only available when connected to the Tailscale VPN.
You can use the special DNS name generated by Pi-hole named pi.hole(so access would be http://pi.hole:port). This is automatically generated and will point to the correct IP, no matter the source interface.
You can also use the automatic IP handling of pi.hole with a local DNS record by using a CNAME record.
I recommend choosing something like raspberryname.home.arpa or raspberryname.yourdomain.com as your domain.
Add it in the Web Interface via: Settings > Local DNS Settings > Local CNAME records.
Domain: raspberryname.home.arpa Target: pi.hole
Wow thanks a lot.
Will try and follow up
I tried and failed:
If I change nothing but simply try to open my raspberrypi resource from any device (PC or IPhone) via http://pi.hole:port the URI can’t be found. The browser times out.
Is this expected?
I then added in the admin web interface under DNS Records (CNAME list):
Domain: raspberrypiname.home.arpa
Target: pi.hole
Then on raspberry: sudo reboot
No change of behaviour when using raspberrypiname.home.arpa, which in turn I expected because pi.hole doesn’t seem to be valid anyway.
BTW: I left TTL empty because I don’t know what to put there.
Should I have done something else too?
Thanks
Update: I executed getent hosts pi.hole on my raspberry and got as an answer 172.21… pi.hole
Is this the docker ip? Is therefore http://pi.hole only accessible within the container?
are you using docker networking mode host or bridge?
additionally, could you post your docker compose file or run command?
Re. docker networking mode: I don’t know. How do I find out?
Re. docker compose file:
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    ports:
      # DNS Ports
      - "53:53/tcp"
      - "53:53/udp"
      # Default HTTP Port
      - "80:80/tcp"
      # Default HTTPs Port. FTL will generate a self-signed certificate
      - "443:443/tcp"
      # Uncomment the below if using Pi-hole as your DHCP Server
      #- "67:67/udp"
      # Uncomment the line below if you are using Pi-hole as your NTP server
      #- "123:123/udp"
    environment:
      # Set the appropriate timezone for your location from
      # https://en.wikipedia.org/wiki/List_of_tz_database_time_zones, e.g:
      TZ: 'Europe/Berlin'
      # Set a password to access the web interface. Not setting one will result in a random password being assigned
      FTLCONF_webserver_api_password: 'password'
      # If using Docker's default `bridge` network setting the dns listening mode should be set to 'ALL'
      FTLCONF_dns_listeningMode: 'ALL'
    volumes:
      # For persisting Pi-hole's databases and common configuration file
      - './etc-pihole:/etc/pihole'
      # Uncomment the below if you have custom dnsmasq config files that you want to persist. Not needed for most starting fresh with Pi-hole v6. If you're upgrading from v5 you and have used this directory before, you should keep it enabled for the first v6 container start to allow for a complete migration. It can be removed afterwards. Needs environment variable FTLCONF_misc_etc_dnsmasq_d: 'true'
      #- './etc-dnsmasq.d:/etc/dnsmasq.d'
    cap_add:
      # See https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
      # Required if you are using Pi-hole as your DHCP server, else not needed
      - NET_ADMIN
      # Required if you are using Pi-hole as your NTP client to be able to set the host's system time
      - SYS_TIME
      # Optional, if Pi-hole should get some more processing time
      - SYS_NICE
    restart: unless-stopped
If you didn't define any network mode, docker will use the default mode: bridge.
OK, thanks. I thought so, but couldn’t find any website telling me this for sure.
Question remaining is: Is my docker-compose.yml good enough for what I want?
I’d recommend using docker’s host networking mode for this.
This will make Pi-hole share the same IP-address as the host.
When using host you won’t have any port mappings, so set Pi-hole’s web ports as to not conflict with other services.
adapted compose file:
services:
  pihole:
    network_mode: host
    environment:
      TZ: 'Europe/Berlin'
    volumes:
    cap_add:
      - NET_ADMIN
      - SYS_TIME
      - SYS_NICE
Great!! http://pi.hole/admin is now callable from PC and from Iphone in local wifi.
So is http://raspberryname/admin itself from PC.
However I still had the original issue:
Coming from outside via Tailscale vpn with my Iphone still only http://raspberryname/admin worked whereas in local Wifi I still had to use raspbertyname.local.
Then I added in the web admin page under
Settings -> Local DNS Records -> List of local CNAME records
  • Domain: raspberryname (without suffix “.home” or anything like that)
  • Target: pi.hole
Now I can access the same URL http://raspberryname:port from IPhone regardless of local Wifi or Tailscale vpn! From PC anyway.
Thanks so much for your help!
MACVLAN is better IMHO :
Each Docker instance gets it’s own IP address within the range of his LAN and thus also WiFi and you will never have any port conflicts as a BONUS! :slight_smile:
