I'm trying to get my PiHole setup but i ran into a problem where i can't change the DNS settings on my bt wifi hub no matter what i try and do im a complete novice at anything to do with networking and i feel like I'm hitting my head against a brick wall with this
I've set my pihole to run as a DHCP server and got my DNS stuff set up and a few blocklists so i thought that would be all i needed to do after disabling the DHCP on my router but i guess not
as I've said I've managed to get the DHCP server set up on my pi and disabled the DHCP on my bt router and it seems to have changed nothing at all and I'm getting queries logged but they seem to be blocking absolutely nothing on any device in the house
Your debug log shows that Pi-hole is working normally, and receiving LAN queries on the vmbr0 interface.
[✓] 8310003.fls.doubleclick.net is 0.0.0.0 on lo (127.0.0.1)
[✓] 8310003.fls.doubleclick.net is 0.0.0.0 on vmbr0 (192.168.1.76)
[✓] doubleclick.com is 142.250.178.14 via a remote, public DNS server (8.8.8.8)
However, Pi-hole is configured for the eth0 interface, which does not have an active IP:
*** [ DIAGNOSING ]: Network interfaces and addresses
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master vmbr0 state UP group default qlen 1000
link/ether e4:5f:01:f1:74:fb brd ff:ff:ff:ff:ff:ff
PIHOLE_INTERFACE=eth0
Run pihole -r and select the reconfigure option to get Pi-hole configured for the active interface.
Repair or Reconfigure --> choose Reconfigure then OK (use the arrow keys and Tab key to move around and Enter to select)
This installer will transform... --> OK
Pi-hole is free... please do donate... --> OK
Static IP Needed --> Continue
Choose An Interface ––– This screen should show you your network interfaces and vmbr0 should be on there. Select that by going to it and using Space. Then --> Select
Then continue the setup. Once done it should working.
*** [ DIAGNOSING ]: Network routing table
default via 192.168.1.254 dev vmbr0 proto kernel onlink
192.168.1.0/24 dev vmbr0 proto kernel scope link src 192.168.1.76
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
Pi-hole is still configured for the eth0 interface:
