beautiful webpage
503 - Service not available
I think the issue is this error (below), but not sure how to fix it. I also get php crit errors further down. When I use debug console, it does indeed get to lighttpd. Even when i do curl -i pi.hole/admin it shows lighttpd running .
---= Detecting Installed Package Versions:
::: Pi-hole: v3.1.4 (master:v3.1.4-0-gb0ecedd)
::: Pi-hole Dashboard: v3.1 (master:v3.1-0-gf204b71)
::: lighttpd/1.4.35
::: Failed loading ext/opcache.so: ext/opcache.so: cannot open shared object file: No such file or directory
Appreciate the help. I ended up getting another PHP error so I just purged all the php files and reinstalled. That seemed to fix the error. However, it's still showing service unavailable - 503 error.
Plex doesn't run on that port. However, I stopped the service completely (to be sure) and still not seeing the webpage. Let me know if you want me to resend debug token.
