Upon trying to access ip-address/admin web page
Web interface, "Connection Refused"
[https://tricorder.pi-hole.net/awy5bzs6p0]
I've noticed this issue documented many times, but none appear to address what I'm seeing in journalctl -xe lighttpd
Nov 27 15:03:14 raspberrypi systemd[1]: Starting Lighttpd Daemon...
Nov 27 15:03:14 raspberrypi lighttpd[21384]: Number found where operator expected at /usr/lib/arm-linux-gnueabihf/perl/5.28/Socket.pm line 4, near "uSe 5.006001"
Nov 27 15:03:14 raspberrypi lighttpd[21384]: (Do you need to predeclare uSe?)
Nov 27 15:03:14 raspberrypi lighttpd[21384]: syntax error at /usr/lib/arm-linux-gnueabihf/perl/5.28/Socket.pm line 4, near "uSe 5.006001"
Nov 27 15:03:14 raspberrypi lighttpd[21384]: BEGIN not safe after errors--compilation aborted at /usr/lib/arm-linux-gnueabihf/perl/5.28/Socket.pm line 11.
Nov 27 15:03:14 raspberrypi lighttpd[21384]: Compilation failed in require at /usr/share/lighttpd/use-ipv6.pl line 3.
Nov 27 15:03:14 raspberrypi lighttpd[21384]: BEGIN failed--compilation aborted at /usr/share/lighttpd/use-ipv6.pl line 3.
Nov 27 15:03:14 raspberrypi lighttpd[21384]: 2019-11-27 15:03:14: (configfile.c.1461) command "/usr/share/lighttpd/use-ipv6.pl 80" exited non-zero: 255
Nov 27 15:03:14 raspberrypi lighttpd[21384]: 2019-11-27 15:03:14: (configfile.c.1289) source: /etc/lighttpd/lighttpd.conf line: 62 pos: 14 parser failed somehow near here: (EOL)
Nov 27 15:03:14 raspberrypi systemd[1]: lighttpd.service: Control process exited, code=exited, status=255/EXCEPTION
Nov 27 15:03:14 raspberrypi systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Nov 27 15:03:14 raspberrypi systemd[1]: Failed to start Lighttpd Daemon.
Nov 27 15:03:14 raspberrypi systemd[1]: lighttpd.service: Service RestartSec=100ms expired, scheduling restart.
Nov 27 15:03:14 raspberrypi systemd[1]: lighttpd.service: Scheduled restart job, restart counter is at 5.
Nov 27 15:03:14 raspberrypi systemd[1]: Stopped Lighttpd Daemon.
Nov 27 15:03:14 raspberrypi systemd[1]: lighttpd.service: Start request repeated too quickly.
As you can see, pihole is functioning, its just the web interface that's being a bugger
pi@raspberrypi:/var/log/lighttpd $ pihole status
[✓] DNS service is running
