If someone is using Unbound and it's normal DNS caching function, is it safe to edit /etc/dnsmasq.d/01-pihole.conf and set the cache-size there to 0? I haven't noticed any ill effects of doing so, but wasn't sure if it could have repercussions that I'm just not seeing.
It is "safe" but not recommended. The developers recommend leaving the Pi-hole cache enabled at all times.
Let each cache operate and they will get along fine.
Gotcha. Wasn't sure if there would be an issue with competing caches leading to stale cache issues or anything.
I run all my Pi-holes with unbound and all (six of them) have both caches enabled and never a problem.
Hi jfb,
can you tell us how to update Unbound to actual release 1.13.0 ?
Cheers
B.
Why ?
If your distribution package manager has a package for unbound you can skip this step, just install the package with your package manager.
NLnet Labs Documentation - Unbound - Howto Setup and Install
pi@ph5:~ $ sudo apt update
21 packages can be upgraded. Run 'apt list --upgradable' to see them.
pi@ph5:~ $ apt policy unbound
unbound:
Installed: 1.9.0-2+deb10u2
Candidate: 1.9.0-2+deb10u2
Version table:
*** 1.9.0-2+deb10u2 500
500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
100 /var/lib/dpkg/status
Just to use the latest release.
Does'nt it make sense ?
Latest release is not always the best release.
New bugs or security risks might have been introduced unnoticed yet.
Thats one of the reasons the "stable" release for most distro's trail behind a bit to evaluate.
Latest apt package is 1.9 on my Raspbian RPi. Is the 1.13 way better that is worth compile it or just wait?
Is it worth living on the edge?
Go mainstream to avoid problems.
Even more, there are apps where I wait a while before upgrading like Domoticz on my RPI.
Ok ... fine. I'll wait.
I just asked for updates not bcause of new features but to be more secure using newer routines.
The Pi is online 24/7 so it's likely that it will be compromised somewhen.
That's my concern.
How so? Do you have untrusted software or users on your LAN?
No. But do you think your network is safe ?
Yes, I do.
Edit - safe enough for my purposes.
What's your threat model? Trying to keep the kids off TikTok or trying to be the next Edward Snowden and are worried about State-level actors?
I'm no stranger to the tin-foil but you have to know who your adversary is in order to know what actions you need to take.
No network is safe.
If you want to keep unbound on latest release, you should also consider compiling latest releases for the other software (and their dependencies) that unbound depends on including the kernel:
pi@ph5:~ $ apt depends unbound
unbound
Depends: adduser
Depends: dns-root-data
Depends: lsb-base (>= 3.0-6)
Depends: openssl
Depends: unbound-anchor
Depends: libc6 (>= 2.28)
Depends: libevent-2.1-6 (>= 2.1.8-stable)
Depends: libfstrm0 (>= 0.2.0)
Depends: libprotobuf-c1 (>= 1.0.1)
Depends: libpython3.7 (>= 3.7.0)
Depends: libssl1.1 (>= 1.1.1)
Depends: libsystemd0
Suggests: apparmor
Enhances: munin-node
That's called Gentoo.
Thank you all for your answers.
