Bulk blacklist/whitelist
Proposed feature(s): Bulk blacklist/whitelist input
Similar in interface to the feature for adding multiple ad and malware [subscription] lists, but for the purpose of bulk user input of domains for blacklist and whitelist purposes. Currently, the user must enter each domain individually to either the blacklist or whitelist. Allowing for multiple entries can save the user time if this can be processed efficiently by pi-hole.
Thank you for checking out this feature request. Thank you for your time.
I believe this already exists. Make a text file with a domain on each line. Then select the contents of the file, paste into the whitelist "add a domain" section, and click "add". This should put them separately into the whitelist.
I never knew this existed. Thus the feature request.
Implemented long time ago via *.txt file , but also possible with v5.0's database
https://github.com/pi-hole/AdminLTE/pull/1149
