Built-in console/terminal on web interface
Hi there,
I hope this wasn't requested earlier and is therefore no duplicate.
I'm highly missing some option to have direct access to the console, especially to execute the updates. At the moment I'm always accessing via SSH since I have the PiHole running on a physical Raspberry.
Since I recently started using Proxmox for different projects, it's insanely comfortable to have a browser-embedded terminal to not need the workaround by connecting via SSH to the machine.
I'd highly appreciate to have such web-embedded terminal/console for the PiHole aswell.
Thanks for your time studying this request and probably taking into consideration for some future update.
Cheers.
Not sure if this will be possible.
For security reasons, the new web server runs with restricted permissions. It can't run commands with elevated permissions, so I don't think we will be able to embed a console/terminal.
