Building a blocklist in Github or other
I am relatively new to all this, but have been running my pi-hole for about 6 months now and have been happy with the results so far.
I am looking to block more domains from my network. Specifically online gaming sites like addictinggames.com and stickgames.com.
I have added these to a github and then loaded that into my pihiole using the GUI but the sites are not blocked. I believe I have a format or reference issue that prevents these from being added to the pihole.
Here is the github link for reference
Thanks for the help.
Use the "Raw" link (is button on GitHub):
I used the raw link and was still able to access the sites I had blocked.
Side not but may be related, when updating my lists it takes quite a long time.
Did you check pihole -q <DOMAIN> ?
addictinggames.com
silvergames.com/en
oakdalegames.weebly.com
sites.google.com/site/bestunblockedgames66/home
stickgames.com
You cant uses slashes etc, only domain names like sites.google.com
addictinggames.com was my trial and never was able to get it to block, so didnt move down the list to try other sites.
would the slashes kick the whole list?
Yes only domains! (EDIT: not sure if kicks the whole list)
After you fixed the github list and reimported the raw link into Pi-hole:
pihole -q addictinggames.com
nslookup addictinggames.com
See the results below, I am still able to access the site.
pi@raspberrypi:~ $ pihole -q addictinggames.com
Match found in list.16.raw.githubusercontent.com.domains:
addictinggames.com
pi@raspberrypi:~ $ nslookup addictinggames.com
Server: 127.0.0.1
Address: 127.0.0.1#53
Address: 0.0.0.0
Address: ::
What is the specific URL you are loading? Please tail the pihole log with pihole -t while you load that site on your browser and post the output here.
See results below.
23:19:24 dnsmasq[1181]: query[AAAA] www.addictinggames.com from 192.168.1.1
23:19:24 dnsmasq[1181]: /etc/pihole/gravity.list www.addictinggames.com is 0.0.0.0
Also how do I stop the -t command?
Ctrl - C stops the tail command.
If you can access the site and it is blocked by Pi-Hole, then either the browser has it in cache still, or there is another DNS server available to the browser or there is another URL it is loading.
It seems to be blocking the functionality of the games now but does not display "site can't be reached" like I expected.
I have tinkered enough tonight, back at it tomorrow.
Thanks for everyones help.
Pi-Hole will only display a block page if you configure it do so, and then only if the page is an http page (won't work on https due to required certs for SSL).
