_TANTE
October 30, 2016, 10:15am
1
Suggestions on this?
Run the -up to update and got to 2.9.5 but webinterface stayed at 1.4.4.
Now nothing seem to work. Also tried doing manuall update using git checkout and pull
About the Swedish: Filen eller katalogen finns inte = File or catalog dont exist
My Swedish is horrible, but try a pihole -d
and then let us know what the token you get is so we can look up the debug information.
_TANTE
October 30, 2016, 10:23am
3
Sorry just saw it. -d gives same error. File or catalog dont exist.
Okay, ls -lach /opt/pihole
should list all of the pihole scripts if they exist.
_TANTE
October 30, 2016, 10:26am
5
Nothing. Catalog dont exist..
Okay, then the install script did not run completely as you don't have any of the Pi-hole files. How about cd /etc/.pihole/
and then git status
_TANTE
October 30, 2016, 10:30am
7
/etc/.pihole $ git status
På grenen master
Din gren är à jour med "origin/master".
inget att checka in, arbetskatalogen ren
Hate i have swedish right now.
Something like On green master
Green current with origin/master
nothing to check in, working catalog is clean
Origin/master is where you want to be. Try running the curl -sSL https://github.com/pi-hole/pi-hole.git | bash
one more time and see if you get a good installation.
_TANTE
October 30, 2016, 10:33am
9
/etc/.pihole $ curl -sSL GitHub - pi-hole/pi-hole: A black hole for Internet advertisements | bash
bash: rad 5: syntaxfel nära den oväntade symbolen "newline"
bash: rad 5: `'
curl: (23) Failed writing body (394 != 1370)
_TANTE
October 30, 2016, 10:35am
10
All this happened today after running -up, before everything worked like a charm!
Very sorry, switch two websites... curl -sSL https://install.pi-hole.net | bash
_TANTE
October 30, 2016, 10:39am
12
Everything works now, the command worked after choosing update. big thanks!
Great! Thanks for using the Pi-hole!
