Brand New to RaspBerry Pi and Pi-Hole...Need Help
_pi hole installed on Raspberry Pi 4 on Raspbian 10 with 8GB RAM
_after following the steps from "pi-hole.net" and having to use the Alternate method #2 from github, I run the install and I receive the following error:
"Retrieval of supported OS list failed. dig failed with return code 10.
Unable to determine if the detected OS (Raspbian 10) is supported"
I then run code according to the fresh install instructions:
curl -sSL https://install.pi-hole.net | PIHOLE_SKIP_OS_CHECK=true sudo -E bash
this then returns: curl (6) Could not resolve host: install.pi-hole.net
I do not have access to the internet (WiFi) anymore broadly.
_IDK what this means
Edit the nameserver line in your resolv.conf to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
sudo nano /etc/resolv.conf
Then retry running Pi-hole's installation.
The installer also needs to be able to do below DNS lookup:
dig +short -t txt versions.pi-hole.net @ns1.pi-hole.net
If above one fails, your router is most likely blocking DNS as part of some router security feature.
pi@ph5:~ $ dig +short -t txt versions.pi-hole.net @ns1.pi-hole.net
"Raspbian=9,10 Ubuntu=16,18,20 Debian=9,10 Fedora=31,32 CentOS=7,8"
