BOGUS domain which is not BOGUS?
www.teleman.pl should not be listed as BOGUS domain when DNSSEC is activated in piHole
piHole shows "BOGUS" status for domain www.teleman.pl. Trying to "dig" the domain with either pdns-recursor or Google's upstream server does not indicate any DNSSEC problems. Here is the output:
resolution with piHole: dig www.teleman.pl @127.0.0.1 +dnssec +multi
; <<>> DiG 9.9.5-9+deb8u17-Raspbian <<>> www.teleman.pl @127.0.0.1 +dnssec +multi
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 22447
; EDNS: version: 0, flags: do; udp: 512
;www.teleman.pl.                IN A
;; Query time: 4 msec
;; WHEN: Tue Apr 30 10:03:31 CEST 2019
;; MSG SIZE  rcvd: 43
resolution with pdns-recursor: dig www.teleman.pl @127.0.0.1 -p 5454 +dnssec +multi
; <<>> DiG 9.9.5-9+deb8u17-Raspbian <<>> www.teleman.pl @127.0.0.1 -p 5454 +dnssec +multi
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 28181
www.teleman.pl.         2161 IN A 195.201.153.25
;; Query time: 1 msec
;; SERVER: 127.0.0.1#5454(127.0.0.1)
;; WHEN: Tue Apr 30 10:04:21 CEST 2019
;; MSG SIZE  rcvd: 59
resolution with Google: dig www.teleman.pl @8.8.8.8 +dnssec +multi
; <<>> DiG 9.9.5-9+deb8u17-Raspbian <<>> www.teleman.pl @8.8.8.8 +dnssec +multi
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 2653
www.teleman.pl.         232 IN A 195.201.153.25
;; Query time: 25 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Tue Apr 30 10:05:01 CEST 2019
So it seems to me that there is something going wrong on piHole side...
https://tricorder.pi-hole.net/iqm2dts12r!
Thanks for help!
Bye
DNSSEC Analyzer test result.
For me everything is green besides the last section (which includes red entries in almost all domains I tested). Funny thing is that the first time I tried that there were some timeouts listed in first and second sections.
Can you try to repeat the query on posted page? Maybe this is something related to temporary unavailability...?
Thanks!
Bye
One more information that might be important:
My local pdns-recursor is configured in the following way:
dnssec=validate
hint-file=/etc/powerdns/named.root
local-address=127.0.0.1
local-port=5454
query-local-address6=::
That means it also validates dnssec entries. In case of www.teleman.pl it returns a valid entry (as posted above). In case DNSSEC would fail, it would also return a SRVFAIL. So why is piHole behaving different here?
Thanks!
Bye
Thanks for the answer!
The disadvantage here is that in the query log of piHole we will never see the dns security status any more, but I guess this is something I can live with :slight_smile:
Bye
