Blocklist error on QNAP container
  • Operating System (Family and Version): ARM
  • Hardware: QNAP TS-216g
  • Container Station Version 3.1.1.1451 (2025/05/27)
  • Docker engine version: pihole/pihole nightly
Installed PiHole nightly with the same method in Pi Hole Docker Container on QNAP NAS
I am able to login, create clients and groups. I can set my devices to manually use the pi-hole and i see results and can test that it is blocking.
But i am not able to add any blocklists.
I put a blocklist link in the address and click “Add blocklist” button and i get the reply:
Invalid request: Specify type parameter (should be either "allow" or "block")
{"error":{"key":"bad_request","message":"Invalid request: Specify type parameter (should be either \"allow\" or \"block\")","hint":null},"took":0.000299215316772461}
https://tricorder.pi-hole.net/L1t7JQgq/
Confirm the issue. We’re investigating.
Should now be fixed with Fix addList function to include type in API request URL by PromoFaux · Pull Request #3620 · pi-hole/web · GitHub merged into development.
You can wait for the next nightly or follow the build instructions on the docker repo to build your own copy locally
Thank you. This is now working.
