Blocking Stopped
Please ensure that you are running the latest version of the beta code.
Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Problem with Beta 5.0:
I do not believe I changed anything but when I woke up yesterday I noticed that nothing is being blocked. From looking at the debug log blocking is disabled in FTL. I have update the OS, updated pihole, and ran pihole -r in repair mode. This only occurred on one of the three pis I have running.
https://tricorder.pi-hole.net/winh1tk8me
Is there any way /etc/pihole/setupVars.conf could have been edited? The file contains an invalid character.
BLOCKING_ENABLED=true/
The trailing slash is breaking things.
Note related to this problem, but you have two IP addresses assigned to the WLAN0 interface:
[✓] IPv4 address(es) bound to the wlan0 interface:
   192.168.0.197/24 matches the IP found in /etc/pihole/setupVars.conf
   192.168.0.200/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
I did not edit it but removing the invalid character did fix it.
Thanks.
This is intentional. I have been running multiple pi's using a high availability script using the keepalived package. The second IP is virtual. I am planning to remove it and when I remove the third pi from use. And just run the two pi zero w's I have as primary and secondary DNS. With the addition of the new database scheme I have just been copying the entire database from one pi to the others when I make a change instead of using the gravity sync script. I have not found any negative effects of copying the database yet.
