Blocking randomly generated domain names
Hello!
I would like to say that I really love Pi-Hole and love how the community has come together to make it better everyday. I downloaded an Android app and saw that the ads were still displaying (removed the app when I couldn't fix it). I looked into the logs and saw that the program (or ad server?) was generating random domain names to circumvent efforts to block the offending source.
I was wondering if there is anyway to customize a blacklist through maybe regex or some means to try to overcome this 'feature.' This was all done through the GUI (trying to block them). I realized there would be more randomly generated domains then I could manually blacklist. I've attached the logs in question. Any suggestions/ideas are most welcome. thank you!
Time Type Domain Client Status Action
6/11/2017 12:09 IPv4 rugfjtysgw 192.168.xxx.xxx OK (cached) Blacklist
6/11/2017 12:09 IPv4 toirijehmfq 192.168.xxx.xxx OK (cached) Blacklist
6/11/2017 12:10 IPv4 lqnqggtkrnofq 192.168.xxx.xxx OK (cached) Blacklist
6/11/2017 12:10 IPv4 refpfrwxmw 192.168.xxx.xxx OK (cached) Blacklist
6/11/2017 12:10 IPv4 zyjeljeocrcl 192.168.xxx.xxx OK (cached) Blacklist
Usually that type of randomly generated domain name is used by chrome to check if your connection is in a captive portal. The ads are probably coming through other domains.
