Blocking ads on DailyMotion
I'm seeing lots of ads appearing on dailymotion.com typically every 5 minutes there are two 30 second ads.
Is there anyway to block these?
Thanks!
These may be served from the same domains that serve the content, which makes it difficult for Pi-Hole to block, since Pi-Hole is a domain blocker.
These tools will help you determine where the ads are served from. If they come from the same domains as the content, you may need to add a browser-based ad blocker (uBlock Origin is one), which may be able to block the ads. Or, if the subdomain for the ads does not change, then blacklist that subdomain.
