Block .zip and .mov by default
As Brodie explains very well here, please disallow .zip and .mov domains.
I do not have enough "carma" or history or point or whatever to make a feature request. So I hope this will do.
Simply starting blocking these domains by default doesn't seem right in my opinion. Your Pi-hole blocks only what either you configure or what is on one of the adlist you added. You can easily block, e.g., zip by adding a blacklist regex like
\.zip$
Furthermore, Pi-hole supports ABP syntax for adlist that easily allow for blocking entire TLDs.
I will make your post a feature request nonetheless.
