Block youtube to a specific device?
Hi Folks,
I was wondering if i can use Pi-hole home to block all Youtube access (not just ads) to specific devices on my network without impacting Youtube access to all other devices?
Many thanks
You can use the Group Management on the web interface:
  • You create a new Group.
  • Then you go to Clients and add the clients you want to the new group.
  • After that, you use the Domains, add the domain or regex you want to block
  • After adding the new domain/regex, use the last column to select only the new group
