Block Specific Websites
I am trying to block some specific websites with my pi-hole, namely YouTube, Facebook, and some others that distract me the most. However I have them added to my blacklist, but they are still freely accessible, aka not blocked. I am using my pc connected to my modem via Ethernet, and my Pi is also connected via Ethernet.
anyone know why and what I can do to solve this problem?
Thanks.
Your regex don't contain domains, but also the protocols and in one case the URL
Remove the http::// and the /wiki from the regex.
so like this?
cause it's not working
Blacklist add domain (check "wildcard"):
No http, https nor www!
youtube.com
youtu.be
For facebook:
facebook.com
facebook.net
facebook.**XX**
include even facebook.XX where XX is Your country (or countries to be blocked).
I.e .de .be .se .no .fi. ie ...
This is not an RegEx expression. Change the Type to "Backlist".
TY, missed that!
Okay, so I have done this, and it is successfully blocking Facebook, but Youtube still works fine. I also disabled the blocks on Facebook, but I still cannot access it, even minutes after
If You are running Windows You should try to clear DNS cache and refresh network settings:
Command-line (CMD):
IPCONFIG /RELEASE
IPCONFIG /FLUSHDNS
IPCONFIG /RENEW
Just to verify that DNS settings are properly updated.
The new screenshot shows all RegEx, but you selected Exact Blacklist. You need to change the type of those.
okay thank you I got it working with this, but it takes a while for Pi-Hole to start blocking it. Why is this and can it be fixed?
What do you mean?
I enable it, but I still have access to the website for a few minutes
Uploading: image.png(1)...
also I'm having a problem where I unblocked Facebook at least 20 minutes ago and it's still blocked by Pi-Hole
here is the screenshot of all of the facebook domains that I normally have blocked (since it won't load on the previous post)
This is normal, in case you have been visiting the site before - your local browser is caching the IP.
Tools > Generate Debug Log
https://tricorder.pi-hole.net/3z16yiIA/ is my debug token. I find it weird, because Youtube and Facebook interact differently with th Pi-Hole. Youtube is blocked/unblocked pretty normally, but Facebook is pretty much permanently blocked
Maybe FB is still blocked even when your RegEx are disabled because you have this adlist enabled?
   5            1  0             https://raw.githubusercontent.com/crpietschmann/pi-hole-blocklist/main/social-media/blocklist-social  2022-05-23 09:29:43  2022-05-26 06:36:13
                                 -facebook.txt
oooooh ok that makes a lot more sense. Thank you
