I'm modifying my Pi-hole to block specific websites after a defined period of time. Thing is, I'm not at all conversant with Github or c, just a bit of python. In essence it scans Pi-hole's log for instances of a local ip address accessing a site, then logs the accumulated time. Once the time limit has been reached it write a regex expression to Pi-hole's regex.list to prevent further access.
I know it's not strictly part of Pi-hole's raison d'etre, but I thought it'd be a nice feature to potentially merge into the main Pi-hole system.
Thanks for looking
Graham
import re, datetime, time, argparse, os
parser = argparse.ArgumentParser(description = "PiHole log parser")
parser.add_argument("-i",default="192.168.#.#", help="ip address to scan for")
parser.add_argument("-c",default="#####", help="content/url segment to scan fo$
parser.add_argument("-t",default=90,help="time to limit it to in mins")
args = parser.parse_args()
destIp=args.i
banned = args.c
limit = args.t
print(destIp, banned, limit)
filepath = "/var/log/pihole.log"
regexlist = "/etc/pihole/regex.list"
oldregex = "/etc/pihole/regex.old"
time1 = 0
time2 = datetime.datetime(1900,1,1,0,0,0)
while True:
usageTime = 1
with open(filepath) as fp:
line = fp.readline()
while line:
match=(re.search(banned+".*."+destIp,line))
if (match):
dateTimeStr = line[0:15]
dateTimeObj = datetime.datetime.strptime(dateTimeStr, '%b %d %H:%M:%S')
#print(time1,time2)
if(time1 == 0):
time1 = dateTimeObj
df = (time2 - time1).seconds/60
if (df<3):
time1 = time1.replace(second=0, microsecond=0)
time2 = time2.replace(second=0, microsecond=0)
df = int((time2-time1).seconds/60)
usageTime=usageTime+df
fp.close()
print("Usage time for ",banned,", ",destIp," is ",usageTime," minutes")
if int(usageTime)>=limit:
print("Over time...."+limit)
f = open(regexlist,"a+")
inline = 0
searchlines = f.readlines()
f.seek(0)
for line in searchlines:
if banned in line:
inline = 1
if inline == 0:
f.write("((^)|(\.))"+banned+"\.\r\n")
else:
print ("under time..."+limit)
with open(regexlist,"r+") as f:
f.seek(0)
if banned not in line:
f.write(line)
f.truncate()
f.close()
os.system("sudo service pihole-FTL restart")
time.sleep(60)
