block ip address range
Hello, is it possible to block an ip range in my dns, for example: 10.10.0.1/22, all this block not query my DNS?
pihola
Why are devices you don't want use your Pi-hole at all?
I'm define this ip range for blocked clients that should not have access to the Internet, for this reason I wanted to block this ranger so that they do not send requests to the DNS server
If they use Pi-hole as DNS server (e.g. you distribute Pi-hole's IP as DNS server via DHCP) they will continue to send queries to Pi-hole.
However, you can block DNS resolution for them via the Group Management. Define a new group for those devices and add a new client as 10.10.0.1/22 to this group only. Then assign an all blocking regex to this group.
Right, they just query the DNS requests on the PIHOLE, the DHCP delivery is done by another device
