Blacklisting and Whitelisting doesn´t work
Blacklisting and Whitelisting should work.
  • Dashboard shows Top Permitted Domains with *fritz.box but only from my Huawei P10 Plus as Client
  • log-ingestion-eu.samsungacr.com is on my Blocklist and it will be forwarded.
    dig @127.0.0.1 -p 5353 log-ingestion-eu.samsungacr.com gives me an IP and not NXDOMAIN
  • The Imageboard pr0gramm.com will be blocked since the Update in 4.0. I have every Subdomain on Whitelist and pihole still block. The command: dig @127.0.0.1 -p 5353 pr0gramm.com and with www.pr0gramm.com pull out the IP 37.48.82.97.
  • I deleted every Cache several times from Windows, Chrome, pihole but the result is the same.
  • I also deleted the mentioned domains several times and added them again via the dashboard or via the command pihole -w.
dd9ofaxnk0
Thanks!
NOT an expert, but my interpretation is:
your dig commands got to @127.0.0.1 -p 5353, witch is probably unbound (from the additional info in the topic title.
Unbound doesn't whitelist or blacklist, it forwards the requests coming from pihole-FTL
to verify whitelisting and blacklisting, you should use dig @127.0.0.1 -p 53 OR dig @<your pihole IP address> -p 53, that is where the clients are sending their request to, and this will give you the answer you expect, based on your whitelist and blacklist.
I have unbound running on IPv6 fdaa:bbcc:ddee:2::5552, port 5552
pihole is running on 192.168.2.57, the IP used as DNS server for all clients
I have ligatus.com blocked
output from a query to unbound:
dig @fdaa:bbcc:ddee:2::5552 -p 5552 ligatus.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> @fdaa:bbcc:ddee:2::5552 -p 5552 ligatus.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 22619
;ligatus.com.                   IN      A
ligatus.com.            3572    IN      A       35.189.193.103
;; Query time: 0 msec
;; SERVER: fdaa:bbcc:ddee:2::5552#5552(fdaa:bbcc:ddee:2::5552)
;; WHEN: Tue Sep 11 10:57:38 CEST 2018
;; MSG SIZE  rcvd: 56
returns IP 35.189.193.103, the real answer.
output from a query to pihole-FTL (all the clients use this):
dig @192.168.2.57 -p 53 ligatus.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> @192.168.2.57 -p 53 ligatus.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 10103
;ligatus.com.                   IN      A
ligatus.com.            2       IN      A       0.0.0.0
;; SERVER: 192.168.2.57#53(192.168.2.57)
;; WHEN: Tue Sep 11 11:01:34 CEST 2018
returns 0.0.0.0, the answer, as presented to the clients, using 192.168.2.57 (pihole) as DNS server
edit
the whitelist isn't even used by pihole-FTL, is is used to build gravity.list. The gravity.list and black.list are processed by pihole-FTL. If a DNS entry is in that list, the request doesn't even go to unbound, but 0.0.0.0 is replied immediately (OR the appropriate reply for the BLOCKINGMODE you use). Only requests that aren't in the above mentioned lists are forwarded to unbound e.g.
blocked entry (in gravity.list OR black.list):
client -> pihole-FTL -> client
unblocked entry (NOT in gravity.list OR black.list):
client -> pihole-FTL -> unbound -> DNS servers -> unbound -> pihole-FTL -> client
/edit
Thanks first for the technical explanation! I've done the dig command with my Rpi IP and get at pr0gramm.com 0.0.0.0 and at www.pr0gramm.com 37.48.82.97. I have both variants of the domain in the whitelist but I still can not open them. Means to me, whitelist does not work. Before the update to 4.0 ran without problems with and without unbound. I also tested different blocking modes but the result was the same. Is it HTTPS or Chrome? As a layman I can not understand, but only pass on the problem and hope that you have a solution ready or can find / make.
pi@raspberrypi:~ $ dig @192.168.178.32 -p 53 pr0gramm.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> @192.168.178.32 -p 53 pr0gramm.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 53151
;pr0gramm.com. IN A
pr0gramm.com. 2 IN A 0.0.0.0
;; SERVER: 192.168.178.32#53(192.168.178.32)
;; WHEN: Fri Sep 14 12:38:07 CEST 2018
;; MSG SIZE rcvd: 57
pi@raspberrypi:~ $ dig @192.168.178.32 -p 53 www.pr0gramm.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> @192.168.178.32 -p 53 www.pr0gramm.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 14844
;www.pr0gramm.com. IN A
www.pr0gramm.com. 3134 IN A 37.48.82.97
;; WHEN: Fri Sep 14 12:38:08 CEST 2018
;; MSG SIZE rcvd: 61
Thanks for your time.
www.pr0gramm.com redirects automatically to pr0gramm.com
  • what is the result of pihole -q -adlist pr0gramm.com
  • are you sure pr0gramm.com isn't in the black.list
  • are you using wildcards (not officially supported in pihole v4, but used in pihole v3)
  • do you have entries in /etc/pihole/regex.list
generate a debug log, so pihole support can have a look (webinterface / tools / generate debug log). I can't access the result, but pihole support can...
Hi, sorry I was on the heat up on assembly.
Before the update to 4.0, the page ran without problems
The result is :
Match found in Whitelist
img.pr0gramm.com
thumb.pr0gramm.com
full.pr0gramm.com
pr0gramm.com
www.pr0gramm.com
vid.pr0gramm.com
Match found in https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts :
miner.pr0gramm.com
app.pr0gramm.com
escobar.pr0gramm.com
m.pr0gramm.com
www-tb7c.pr0gramm.com
Match found in https://ncloud.zaclys.com/index.php/s/MPYSjLkb8cE8gPN/download:
ner.pr0gramm.com
umb.pr0gramm.com
r.pr0gramm.com
ll.pr0gramm.com
d.pr0gramm.com
w.pr0gramm.com
ner.pr0gramm.com
.pr0gramm.com
cobar.pr0gramm.com
atar.pr0gramm.com
g.pr0gramm.com
rensohn.pr0gramm.com
ns.pr0gramm.com
w-tb7c.pr0gramm.com
pr0gramm.com
p.pr0gramm.com
Match found in https://adblock.mahakala.is/:
app.pr0gramm.com
avatar.pr0gramm.com
full.pr0gramm.com
hans.pr0gramm.com
hurensohn.pr0gramm.com
miner.pr0gramm.com
ww.pr0gramm.com
Match found in https://fanboy.co.nz/r/fanboy-ultimate.txt:
miner.pr0gramm.com
Match found in https://hostsfile.mine.nu/hosts0.txt:
app.pr0gramm.com
avatar.pr0gramm.com
full.pr0gramm.com
hans.pr0gramm.com
img.pr0gramm.com
m.pr0gramm.com
miner.pr0gramm.com
pr0gramm.com
thumb.pr0gramm.com
vid.pr0gramm.com
ww.pr0gramm.com
www.pr0gramm.com
From this Site is have the regex list in my pihole. https://github.com/mmotti/pihole-regex
And I have log-ingestion-eu.samsungacr.com on the blocklist but that will also be redirected.
I had changed the Blocking Modes but this changed nothing.
If i open pr0gramm.com oder www.pr0gramm.com pihole has also an entry of www.google.com blocked but google.com and www.google.com are in the Whitelist.
[✓] Your debug token is: 1g79u6in3s
Thanks for ideas or help!
You aren't on 4.0. You are on the development branch, which has the V4 features with some additional development code. I don't know if this was your intent, but be aware that with development code comes some potential problems. If you wish to return to the stable 4.0 master, use pihole checkout master
[i] Core: v3.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: development (https://discourse.pi-hole.net/t/the-pihole-command-with-examples/738#checkout)
[i] Commit: v3.3.1-467-ga896153
[i] Web: v3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: devel (https://discourse.pi-hole.net/t/the-pihole-command-with-examples/738#checkout)
[i] Commit: v3.3-323-ga87d4e97
[✓] FTL: vDev-a4eabb7 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
Yes, i know that im on dev because since 4.0 i got several problems with some domains. I was testing if changing to dev it was better with the domains. I tryed to checkout master but i got an error.
/etc/.pihole/automated install/basic-install.sh: line 34: setupVars: readonly variable
The checkout bug will be fixed by this PR:
Very, very cool! I manually deleted the entry in the gravity.list and the page works again !!
I have in the Gravity.list but still various entries that start with ."domain". Is that perhaps an option, Domains the only one "." anticipate, delete directly at the list creation in order to avoid mistakes?
I have already tried various things but I did not have that on the list.
Thanks msatter!
I would like to add that, on the latest development branch, the blacklist feature is not working for me either.
What problems are you experiencing with blacklists on dev branch?
Blacklisted items are resolved to their corresponding IP address. Even after waiting >48 hours for devices to clear their cache (even though they shouldn't be cached because I used the dev branch only after upgrading straight from v4.0), it still resolves them. This is not the case with v4.0.
The only way to block them is through a gravity list.
I posted to this topic because the OP was on the dev branch as well and was having the same issue. If you would like me to make a new thread I'd be happy to.
Can you provide some examples from your logs, screens? This will help the devs analyze and duplicate the problem.
Debug Token: 45mk3jgat5
As far as I can tell, the pihole actually does block these requests but it does not register in the Web GUI as such.
For testing purposes, google.com and www.google.com were placed into the blacklist. Upon trying to access either of these, it shows in the Admin Console, "OK (cached)", indicating that the request was successful.
Upon visiting these sites, the connection is correctly refused.
In Chrome, "google.com refused to connect", indicating that it functions as it should. It seems to be a GUI issue.
Your problem appears similar to this open thread:
https://discourse.pi-hole.net/t/domain-being-blocked-but-shown-as-not-blocked-in-query/13272/61
