Blacklist, confused first-time poster
[I think that the domain "tvpnlogopeu.samsungcloud.tv" should be blocked]
[My TV appears to be successfully querying this domain a few thousand times every night, the queries appear as green entries in the Query Log]
[https://tricorder.pi-hole.net/41w5ab8fcr]
I added tvpnlogopeu.samsungcloud.tv to my blacklist from the Query Log in the UI, I also added it as a Wildcard from the Blacklist Management screen in the UI.
The output of this command:
pihole -q tvpnlogopeu.samsungcloud.tv
Is this:
Match found in exact blacklist
Match found in regex blacklist
(.|^)samsungcloud.tv$
(.|^)tvpnlogopeu.samsungcloud.tv$
I must be missing something obvious, but I'm damned if I can understand what. Your assistance appreciated.
Your Samsung TVs are only in the Group with ID 1,all your adlists and blacklisted domains are in the default group (ID 0). Add you TVs to the default group as well, or the adlists and blacklisted domains to group ID 1.
Ah, OK. I see my TVs in a separate group, I'm sure that seemed like a good idea at the time. :slight_smile:
I have done as you have suggested (added the Samsung domains to All groups), let's see how it goes.
Thank you!
Problem solved, thank you very much! For future questions in a similar vein, here is what I did:
In the Pi-Hole UI, I went into Group Management > Groups.
In Safari 14.03 with Pi-Hole 5.2.4 there is a bug that caused my group or groups to initially be displayed incorrectly, I just changed the value in the Show Entries drop-down and the screen refreshed correctly (EDIT: reloading the browser works too).
I deleted my unwanted group (my requirements are simple, so far), so I now only have the Default group now.
I checked in Group Management > Domains to confirm that my Samsung blacklisted domains are now in the Default group.
Actual (New) Behaviour: a sea of red at the usual hour in the Query Log! Thank you for your help, yubiuser.
