I did pihole uninstall
I kep two files
dhcp.leases
04-pihole-static-dhcp
where all my static IP are stored
WHich is the best way, to reinstall all, and then manually add the 2 files or only dhcp.leases (or the other)?
I kep two files
dhcp.leases
Did you keep the /etc/pihole/setupVars.conf
file? You can back up those files and try a reinstall.
