Best Pi-hole setup
What is the best/easiest to setup platform to run pihole? If raspberry pie, what version? Also do you run any software along with it? Im looking for the best setup to block ads on my tv with roku.
That's really for you to decide.
The best setup would be the one that works for you, preferably on a machine that you already run on your network anyway (like a NAS that would allow to run Docker, where in turn Pi-hole's official Docker image could be installed).
If you consider to acquire some new hardware, even cheap boards like RPi Zero are fully sufficient to have Pi-hole filter your home network.
