Why should I avoid to display my hostname?
ATM pi hole is newly installed and it works smooth again. Do you any solution how I can process a debugg if the installed pihole crashes again?
Some users don't like to post the hostname or other "personal" info.
Not a big deal.
Alright, not a problem für me.
Yeah we have to be a bit careful when asking folks to post details about their setup
Check the systemd journals like posted above!
Might want to check for --priority err first before --priority warning.
FYI:
$ man journalctl
-p, --priority=
Filter output by message priorities or priority ranges. Takes
either a single numeric or textual log level (i.e. between
0/"emerg" and 7/"debug"), or a range of numeric/text log levels
in the form FROM..TO. The log levels are the usual syslog log
levels as documented in syslog(3), i.e. "emerg" (0),
"alert" (1), "crit" (2), "err" (3), "warning" (4),
"notice" (5), "info" (6), "debug" (7). If a single log level is
specified, all messages with this log level or a lower (hence
more important) log level are shown. If a range is specified,
all messages within the range are shown, including both the
start and the end value of the range. This will add "PRIORITY="
matches for the specified priorities.
