On the Pi-hole device, the entries do not scroll. On the Pi-hole Query Log there are some entries that are red and green.
If the log is not scrolling then your clients are not querying the Pi-hole for the DNS. And that's what I suspected as the debug log did not show any entries in the portion that captures the query log. How many pages are on the web interface? One or two or more than that?
I moved the Raspberry Pi to the router and used an Ethernet cable. On the Query Log it shows a couple entries, almost all green.
Do you see the IP addresses of the clients being displayed in any of the graphs? And are the counters increasing in the Total Queries when you browse sites with the client?
I have three clients showing in the second graph. The total query number isnt rising.
Can you go to your client and copy the output from ipconfig /all
so we can see what is set there?
`Windows IP Configuration
Host Name . . . . . . . . . . . . : Sharp
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : attlocal.net
Wireless LAN adapter Local Area Connection* 11:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 1E-3E-84-75-E7-74
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : attlocal.net
Description . . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ethernet
Physical Address. . . . . . . . . : 20-89-84-6D-D7-35
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Qualcomm Atheros AR5B125 Wireless Network
Adapter
Physical Address. . . . . . . . . : 1C-3E-84-75-E7-74
IPv6 Address. . . . . . . . . . . : 2600:1700:16e0:b6d0::51e(Preferred)
Lease Obtained. . . . . . . . . . : Monday, July 2, 2018 1:54:14 PM
Lease Expires . . . . . . . . . . : Wednesday, August 1, 2018 1:54:14 PM
IPv6 Address. . . . . . . . . . . : 2600:1700:16e0:b6d0:8967:e7b3:ae19:815(Preferred)
Temporary IPv6 Address. . . . . . : 2600:1700:16e0:b6d0:f7:497:6db5:bfb5(Deprecated)
Temporary IPv6 Address. . . . . . : 2600:1700:16e0:b6d0:479:4cb7:c4a1:8b76(Preferred)
Temporary IPv6 Address. . . . . . : 2600:1700:16e0:b6d0:5573:a70a:a53b:f11c(Deprecated)
Temporary IPv6 Address. . . . . . : 2600:1700:16e0:b6d0:98c5:9215:7053:7a8(Deprecated)
Link-local IPv6 Address . . . . . : fe80::8967:e7b3:ae19:815%3(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.73(Preferred)
Lease Obtained. . . . . . . . . . : Monday, July 2, 2018 7:15:36 AM
Lease Expires . . . . . . . . . . : Wednesday, July 4, 2018 7:04:00 PM
Default Gateway . . . . . . . . . : fe80::d6b2:7aff:fe47:5be5%3 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 354172548
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-01-76-12-20-89-84-6D-D7-35
DNS Servers . . . . . . . . . . . : 2600:1700:16e0:b6d0::1
192.168.1.254
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:c669:fe82:1c15:3028:3f57:feb6(Preferred)
Link-local IPv6 Address . . . . . : fe80::1c15:3028:3f57:feb6%8(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 134217728
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.attlocal.net:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
That IP address is not the Pi-hole address. Looks like that is the IPv6 address of the router. That is how the client is resolving names without querying the Pi-hole.
You said you changed the network connection of the Pi-hole? Can you run a new pihole -d
so that we can see the new configuration?
hj2l908cci
Do i run the curl -sSL https://install.pi-hole.net | bash
to change the Lan to Ethernet? And should I disable IPv6 if I configure?
Ok, some of the ads that are sent through on websites are getting blocked, but some are getting through. Is this because of the IPv6? Or is it some other thing that is allowing them through?
Yes, if the client has the option to use another DNS server, like the IPv6 router, it will use that and will leak advertisements. Take a look at the following threads for some information on how to work around that.
I can see that the IPv6 is letting ads through, but when I check my Queries, it shows two of the same ads- one on IPv4 and one on IPv6. Both are letting them through and blocking them, instead of IPv4 only blocking and IPv6 only letting through. And when I put /etc/pihole/setupVars.conf
I get bash: /etc/pihole/setupVars.conf: Permission denied
Upon reading the second post you showed, it says to make a file for that command. How would I do that?
