Beaglebone - DNS will not start after update
Pi-Hole continues to work after update.
Pi-Hole does not work after update. I can see the webpage but FTL and DNS are dead. I began some steps to install OpenHab but never ran the installer, only updated apt-get items. I had a grand ol' time getting Pi Hole working the first time around as documented here: Pi-Hole on the Beaglebone – Anders K Nelson.
[✓] Your debug token is: https://tricorder.pi-hole.net/g7k1b28njy
What are the outputs of the following commands from the Linux terminal:
sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:8953 \|:67 \|:80 \|:471'
debian@beaglebone:~$ sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:8953 \|:67 \|:80 \|:471'
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      6327/lighttpd
tcp6       0      0 :::80                   :::*                    LISTEN      6327/lighttpd
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1042/avahi-daemon:
udp6       0      0 :::5353                 :::*                                1042/avahi-daemon:
debian@beaglebone:~$ sudo service pihole-FTL status
   Loaded: loaded (/etc/init.d/pihole-FTL; generated; vendor preset: enabled)
   Active: active (exited) since Tue 2020-01-28 05:02:49 UTC; 20h ago
  Process: 7000 ExecStop=/etc/init.d/pihole-FTL stop (code=exited, status=0/SUCCESS)
  Process: 7007 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
    Tasks: 0 (limit: 4915)
Jan 28 05:02:49 beaglebone systemd[1]: Starting LSB: pihole-FTL daemon...
Jan 28 05:02:49 beaglebone pihole-FTL[7007]: Not running
Jan 28 05:02:49 beaglebone su[7036]: Successful su for pihole by root
Jan 28 05:02:49 beaglebone su[7036]: + ??? root:pihole
Jan 28 05:02:49 beaglebone su[7036]: pam_unix(su:session): session opened for user pihole by (uid=0)
Jan 28 05:02:49 beaglebone pihole-FTL[7007]: dnsmasq: illegal repeated keyword at line 33 of /etc/dnsmasq.d/0
Jan 28 05:02:49 beaglebone systemd[1]: Started LSB: pihole-FTL daemon.
lines 1-16/16 (END)
debian@beaglebone:/etc/dnsmasq.d$ cat 01-pihole.conf
# Dnsmasq config for Pi-hole's FTLDNS
#      FILE AUTOMATICALLY POPULATED BY PI-HOLE INSTALL/UPDATE PROCEDURE.      #
#        IF YOU WISH TO CHANGE THE UPSTREAM SERVERS, CHANGE THEM IN:          #
#                      /etc/pihole/setupVars.conf                             #
#        ANY OTHER CHANGES SHOULD BE MADE IN A SEPARATE CONFIG FILE           #
#                    WITHIN /etc/dnsmasq.d/yourname.conf                      #
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=eth0
This is the problem. The file name was cut off but it was likely 01-pihole.conf. Line 33 of this file is
cache-size=10000
There is likely another cache size entry in a separate dnsmasq configuration file. Let's look. What is the output of the following:
ls -lha /etc/dnsmasq.d
cat /etc/dnsmasq.conf
sudo grep cache-size -R /etc/dnsmasq.d
Thanks for the support, here's the output:
debian@beaglebone:~$ ls -lha /etc/dnsmasq.d
total 16K
drwxr-xr-x   2 root root 4.0K Jan 29 01:57 .
drwxr-xr-x 109 root root 4.0K Jan 29 03:18 ..
-rw-r--r--   1 root root 1.4K Jan 29 01:57 01-pihole.conf
-rw-r--r--   1 root root  391 Jan 29 03:18 SoftAp0
debian@beaglebone:~$ cat /etc/dnsmasq.conf
conf-dir=/etc/dnsmasq.d
debian@beaglebone:~$ sudo grep cache-size -R /etc/dnsmasq.d
/etc/dnsmasq.d/SoftAp0:cache-size=2048
/etc/dnsmasq.d/01-pihole.conf:cache-size=10000
This is the problem. SoftAp0 has created a conflicting cache-size statement. Remove the SoftAp0 configuration file and start FTL with
sudo service pihole-FTL start
I commented the line "cache-size=2048", shouldn't that be enough?
debian@beaglebone:/etc/dnsmasq.d$ sudo service pihole-FTL start
debian@beaglebone:/etc/dnsmasq.d$ pihole status
  [✗] DNS service is NOT running
debian@beaglebone:/etc/dnsmasq.d$ cat SoftAp0
interface=usb0
interface=usb1
port=53
dhcp-authoritative
domain-needed
bogus-priv
expand-hosts
#cache-size=2048
dhcp-range=usb0,192.168.7.1,192.168.7.1,2m
dhcp-range=usb1,192.168.6.1,192.168.6.1,2m
listen-address=127.0.0.1
listen-address=192.168.7.2
listen-address=192.168.6.2
dhcp-option=usb0,3
dhcp-option=usb0,6
dhcp-option=usb1,3
dhcp-option=usb1,6
dhcp-leasefile=/var/run/dnsmasq.leases
You should get rid of the entire configuration file to get Pi-Hole running. You'll be chasing conflicts line by line otherwise. Some related threads on this issue.
https://github.com/pi-hole/pi-hole/issues/1521
Haha, owned by my own troubleshooting post! I'm not even mad, that's amazing.
Removed SoftAp0, rebooted.
debian@beaglebone:~$ pihole status
[sudo] password for debian:
  [✓] DNS service is running
Time to donate again, thanks!
Heyoo, FYI the Beaglebone Black BSP loves to regenerate the SoftAp0 file whenever you reboot! You can solve that issue here:
