Basic / Digest authenification to certain pages
I currently have
auth.backend = "htdigest"
auth.backend.htdigest.userfile = "/etc/lighttpd/lighttpd.user"
auth.require = ( "/automation/" =>
"method" => "basic",
"realm" => "automation",
"require" => "user=auto"
In my lighttpd confi, the file exists and is owned by www-data with the perms of 644.
However, when I go to the sub-directory with pi-hole it doesn't ask for password like I expect it to.
Page loads with no hint that is even wanting to ask for a password.
I'm not sure if this is something I should post here to see if pi-hole is somehow stopping it, or ask on the lighttpd forums, but I figured I should check here first since this isn't exactly a stock install of lighttpd.
Did you restart lighttpd after adding that? You might want to add it to the /etc/lighttpd/external.conf file so that it isn't overridden by updates.
Yep restated the service and everything I'll triple check again when I get near my computer and report back
Nope, I triple checked, even checked a few other websites to see if anyone else has had this problem, I even tried doing url.access-deny = ("") on the subdir doing a quick url check like you do... But it didn't even deny it so I think something bigger is hiphop happening...
So you are trying to go to http://pi.hole/automation/ and it is not asking for authentication?
Otherwise I don't see anything in the default Pi-hole config which would stop this from working.
I didn't try pi.hole but it does the same thing, I am beginning to wonder if it's somehow related to the fact it isn't in a subfolder, but another one of my denies work fine... But when I put
$HTTP["url"] =~ "^/automation/" {
AND restarted the service it still let me view the page.
Edit: What I meniontioned is infact untrue.
Is the page you are viewing under /automation and are you going directly to it? Or is it the block page?
It's going directly to it; host/automation loads with no issues, but I've also recently noticed that all stuff like this is being ignored especially url blocks, I do have mod_auth in my server modules and can post the whole config if it would help
The lighttpd forums might be more knowledgeable on this issue than us, sorry.
It's all good thought it was worth a try checking here first
So, if anyone else stuffs up as bad as me, do these steps.
sudo htdigest -c /etc/lighttpd/.passwd 'Authorized users only' <USER>
replace USER with who you want to have access, put this either in your lighttpd or external conf
auth.backend.htdigest.userfile = "/etc/lighttpd/.passwd"
auth.debug = 2
auth.require = ( "/<DIR>/" =>
"method" => "digest",
"realm" => "Authorized users only",
"require" => "valid-user"
Replace DIR with the directory.
Then restart the pi or server with
/etc/init.d/lighttpd restart
Then it works for me.
