Hello, I use pi-hole as a DHCP server and I disabled DHCP server of my ISP router, but I think my microSD is having problems, how do I have to do the installation ?
Disable Pi-Hole DHCP, reactivate the DHCP of the router, install Pi-Hole and put the DHCP on pi-hole, or there is a better solution?
Thank you, but if I disconnect pihole I would not have any DHCP server for my new pi, and does the Teleporter save the static IP that I attributed to pi that uses pihole?
