Please add an option to select exactly what should be included in the backup. Or just two options:
Full backup
Backup lists and domains/regexes
Full backup
selective teleporter stuff isnt in the ui yet from what ive seen. for lists/domains only i usually either run a teleporter export and only restore the pieces i care about on the other box, or pull adlists / domainlist out of gravity / the api and keep that as a skinny backup.
full teleporter zip is still the blunt hammer if you want everything. a lists-only toggle would be nice though.
I understand that, but the opposite approach would be better: If you give a colleague your lists using the teleporter, they’ll have everything from you—your configuration and your 2FA key. That’s why I’m asking—so there are two backup options: a complete one and one just for lists, domains, and regexes.
LOL! That's awkward : Import side has this option, but the Export side doesn't ?! ![]()
It would be cool if this could be synced indeed! ![]()
