Possibility of authentication of accesses through local user base or external sources such as active directory or ldap. login page that forces the user to authenticate before navigating
When the new web interface is released it will be easy to put behind a proxy (Nginx, Apache, etc). There you can apply the login page or whatever else is needed. This should solve any immediate use cases.
would be to authenticate user access. access control in the case, with possibility of creating profiles
example:
Group or user1 = normal access, all domains released
Group or user2 = access with pre-defined domains in lists or through denied blacklist
so it works as well as a content filter for various categories like social networks, videos, pornography, etc.
any plan or more people interested in this?
