Anyone else have ATT fixed wireless? This is the Uverse router. Its running different firmware only thing different is they removed the port forwarding. (pinholes). It connects to a outside antenna. NetComm Wireless Model IFWA661. When I look that up its a Outdoor LTE Router. ATT must be a custom version because its band 30 reserved for fixed only.
I ran it for a while by entering the pi hole dns ip until it started refusing to reserve ips so I figured just use pi hole. Its DHCP cant be disabled so I did as suggested on the att forum set the range to 1 ip and pi hole can now reserve ips. SO 2 DHCP servers running at the same but ATT is full.
But now its getting a IP from pi hole?
192.168.0.245 5268ac no interface on this ip Im confused on what this is doing.
Only other option I can see is to factory reset the modem and reserve my ips before its ip list fills back up with trash ip6 listings all the same value.
