I have a raspberry pi 4 running pi hole with a normal install. I am trying to use the wegmans app on my android phone which fails to load. I looked at the query log and found a few domains were being blocked so I whitelisted them until no more blocked domains showed up.
The Wegmans App still doesn't load after whitelisting everything i found being
blocked. I can disable blocking for a few seconds and it works.
