Hi team! I'm using pihole docker on a Raspberry Pi 1B (yes, "1B") and it's working fine for most of the things, but now that I need to automate some things, I need the Token API.
Using the UI, I could get the Token API but after a while, I've noticed that during my house power outages, the container gets recreated but it lose any new password or even the Token API.
I don't mind too much about the password since I set the WEBPASSWORD environmental variable, but the token API is getting my crazy... any idea why it get's re-created instead of saving to the volumes?
My code is:
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "80:80/tcp"
environment:
TZ: 'America/Chicago'
WEBPASSWORD: 'something'
volumes:
- './etc-pihole:/etc/pihole'
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
restart: unless-stopped```
