Hello!
When, I go to Dashboard > Domains, and add a domain with the option Add domain as wildcard checked, the final domain shown in the WebUI has a single backslash on its string.
Example:
(\.|^)s\.youtube\.com$(\.|^)video-stats\.l\.google\.com$
But, when I check the output of: /.../admin/api-php?list=regex_<list_name>&auth=<token_id>, I get:
(\\.|^)s\\.youtube\\.com$(\\.|^)video-stats\\.l\\.google\\.com$
{"data":[{"id":18,"type":2,"domain":"(\\.|^)s\\.youtube\\.com$","enabled":1,"date_added":1666610508,"date_modified":1680012179,"comment":"","groups":[0]},{"id":19,"type":2,"domain":"(\\.|^)video-stats\\.l\\.google\\.com$","enabled":1,"date_added":1666610517,"date_modified":1680012179,"comment":"","groups":[0]}]}
So, I have the following questions:
1. What file from the GitHub repo contains the regex implementation, so I can take a look how it's working in the background when the user use the user interface, instead of CLI to add a domain with that option checked?
2. I have created the following cmd to do what the Add domain as wildcard option does: echo "%url" | sed 's/^/(.|^)/; s/./\./g; s/$/$/', but don't know if I should modify it to be able to add a second backslash. Or does Pi-hole applies that in the background?
Thank you!
