API Help
http://pi.hole:80/api/config
payload
"config": {
"dns": {
"blocking": {
"active": false,
"timer":30
sid set in header
Please do not hijack other threads.
From this post it's not clear if you experience an issue or not. Please clarify.
The blocking is disabled but the timer value is not honored.
The correct endpoint for enabling/disabling blocking with/without timer is
/dns/blocking
See Pi-hole API documentation
