i have the error port 53 after a power outage/reboot.
can i get dnsmasq and ftl back up using the web gui?
tried to follow this but getting nowhere
debug token is: https://tricorder.pi-hole.net/xfMplmd1/
tia
tia
You have unbound running on port 53. This is preventing pihole-FTL from binding to that port.
[53] is in use by unbound (https://docs.pi-hole.net/main/prerequisites/#ports)
[2022-05-22 15:54:37.843 604M] FATAL ERROR in dnsmasq core: failed to create listening socket for port 53: Address already in use
This is not something you can fix from the web GUI. You will either need to stop unbound or put it on a different port. Our guide for unbound has a configuration file that will put unbound on port 5335 and avoid the port 53 conflict.
Error writing /etc/unbound/unbound.conf.d/pi-hole.conf: Permission denied
You need sudo
powers to modify that file.
sudo nano /etc/unbound/unbound.conf.d/pi-hole.conf
