Android devices refusing to connect to WiFi due to DNS
Thanks for all your work on Pi-Hole, the new Web interface is vastly more complex and I see features a bunch of debugging tools. It must have taken a while to write!
  • My Pi-Hole is fully up to date and running on a fully-patched Debian 12 VM (not in a container).
  • Since I've disabled and stopped lighttpd and added a "Custom DNS Server" for my upstream DNS it seems to be fully functional from PCs on my network.
  • My Android Devices still refuse to connect to WiFi, saying "Can't provide Internet" when the internet has never been unavailable. The problem is DNS.
  • I have always blocked Google DNS servers at my network firewall (you'll notice 8.8.8.8 can't be used to resolve domains in the diagnostics but this is a false-positive. It is not causing the problem as it has not changed in years).
  • Android Devices still won't connect to WiFi after Pi-Hole configuration was fixed after upgrade. I've tried rebooting them to no effect.
  • I can prove the Internet is actually available.
https://tricorder.pi-hole.net/Xzz0OAPU/
The problem might be that I have 3 different internal (private) networks.
It seems dnsmasq configuration in Pi-hole has changed so that it now ignores queries from "non-local" networks. Can someone please help me configure it to permit from the 3 subnets I need it to answer to?
The documentation states that the dnsmasq option "local-service" is now enabled.
but I can't find that option in the UI.
  • How can I reconfigure FTL to respond to "non-local" DNS queries please?
    There does not seem to be a reverse option I could put in an /etc/dnsmas.d/myconfig.conf file to undo it!
I eventually found it in the UI but it hasn't resolved the problem.
Why have there been so many changes made to Pi-hole at once?
Updated https://tricorder.pi-hole.net/Xzz0OAPU/
The problem was resolved by allowing my pi-hole to respond to any IP/network again.
I need to spend more time finding the best option for Interface binding behavior.
It sure was frustrating to wake up to multiple configuration changes, but I'm sure they were changed for a reason. Thanks again for Pi-Hole!
Configure VLAN Interfaces and bind the webGUI only to your Management VLAN IP Address and you are DONE! :wink:
Since Pi-Hole v6 this has become a 5 minute fix basically :+1: :+1:
This is a major version change (V5 to V6) that is a complete rewrite of much of the code. This work has been in progress for over 4 years, and was beta tested for a significant period of time prior to release as V6 (since October 2023).
